Home » Sponsored » Pi Speakers » tweeter compensation in active set-up
are you driving the HF with the quad II's? [message #35093 is a reply to message #35090] Tue, 12 February 2002 07:14 Go to previous messageGo to previous message
Then don't sweat the lost power, if the end result is a more linear freq. response. Sure, you don't have the intimate amp to voice coil interface like the bass driver, but hey, the HF is damped by the network, yes?
Later, you might wish to try learning about the opamps/active filters more, with an eye towards being able to tailor a gain stage to have the desired EQ characteristics the HF needs for being flat. Can also add a stage with low end eq for the bass.
For example, in my preamp, there is a "+6 dB at 50 Hz." contour circuit...all it is, is a cap and resistor in front of a gain stage. There is even a bread board type kit out now, to learn and play with these things. And web resources. Depends on how far down the road in this hobby you wish to travel.
Sounds like you already have your system pretty well sorted out for now. Sam
Previous Topic: More active crossover questions
Next Topic: Day Two in the Life of a 4 Pi
Current Time: Tue Nov 03 15:32:32 CST 2026
