Home » Sponsored » Pi Speakers » 4 pi series/ parallel resistor headache
Re: other problem is no one makes 64 ohm [message #35074 is a reply to message #35073] Sun, 10 February 2002 15:48 Go to previous messageGo to previous message
I would hardly nit-pick over a 1 ohm difference in the network. That's just a little over within 5% tolerance which is better then most resistors anyway. It would make no difference at all 17 ohms or 16 ohms. By the way, power handling is increased with parallel resistors but not with series wired ones. You don't get a power handling gain from a series wiring, exactly the same as inductors.
Adam
Previous Topic: The Theater 4 Pi's WORK!!!
Next Topic: true readings of power,and false readings
Current Time: Tue Nov 03 12:56:26 CST 2026
