Sponsored
4 pi series/ parallel resistor headache
Re: here we go, since it's wayne's day off
message #35068
is a reply to
message #35067
Sun, 10 February 2002 10:52
tdc
May 2009
I quess either of the two ideas works. I understood the fact that the resistance came out but was wondering if the power capacity is the same either way. Sounds like it is. Thanks to you both. tdc
Message index
By:
tdc
on Sun, 10 February 2002 08:16
same question here
By:
trancemitr
on Sun, 10 February 2002 08:50
Us dummies need to stick together!
By:
BillEpstein
on Sun, 10 February 2002 13:56
by george, I think he's got it!(nt)
By:
Sam P.
on Sun, 10 February 2002 14:03
Re: Us dummies need to stick together!
By:
tdc
on Mon, 11 February 2002 06:51
That's Eulenspiegel, Eulenspiegel! Dumkopf!!!!!! (nt)
By:
BillEpstein
on Mon, 11 February 2002 14:59
Re: That's Eulenspiegel, Eulenspiegel! Dumkopf!!!!!! (nt)
By:
tdc
on Tue, 12 February 2002 09:40
And they HUNG me! Ackkkk! (nt)
By:
BillEpstein
on Tue, 12 February 2002 11:02
By:
Sam P.
on Sun, 10 February 2002 09:21
By:
Adam
on Sun, 10 February 2002 10:05
By:
tdc
on Sun, 10 February 2002 10:52
four 64 ohm resistors in parallel
By:
Sam P.
on Sun, 10 February 2002 10:56
Re: four 64 ohm resistors in parallel
By:
Adam
on Sun, 10 February 2002 14:23
other problem is no one makes 64 ohm
By:
Sam P.
on Sun, 10 February 2002 14:35
Re: other problem is no one makes 64 ohm
By:
Adam
on Sun, 10 February 2002 15:48
power handling
By:
Sam P.
on Sun, 10 February 2002 16:19
Re: power handling: Try this .....
By:
BillEpstein
on Sun, 10 February 2002 16:33
Re: power handling
By:
Adam
on Mon, 11 February 2002 08:54
power handling is a
By:
Sam P.
on Mon, 11 February 2002 09:38
Re: power handling is a
By:
Adam
on Mon, 11 February 2002 10:40
The Theater 4 Pi's WORK!!!
true readings of power,and false readings
Tue Nov 03 11:45:36 CST 2026
