Home » Sponsored » Pi Speakers » Seven Pi-18 or Ten Pi-18(long)
Re: Seven Pi-18 or Ten Pi-18 [message #35058 is a reply to message #35052] Sat, 09 February 2002 08:41 Go to previous messageGo to previous message
RichardC is currently offline  RichardC
Wayne,
I haven't found that 18" yet. Anyway, I was reading a review a while back about the effect of increased bass output in small listening areas. The article was primarily about automotive sound systems. He displayed a response curve in open air and superimposed a curve obtained inside of various cars. A small car interior had about a 30db max boost starting below 100Hz that he called the "pressure pot effect". Do you know at what point a room will exhibit this effect? Say, below "so many" square feet we have a noticable increase and above this area is negligible. I have a little over 250 square feet. You said that generally a 500 square foot room would be the minumum for a cornerhorn; so what happens in a room 1/2 that size? Do I lose the bass extension because the sound wave doubles back and cancels? I sure don't want to waste my time if another enclosure design would give me better low bass extension. Until I can get the proper 18" JBL driver to experiment with, I will probably turn my 4508 (4648-8A) into the corner. Its a LOT better than nothing.
Richard
Previous Topic: 2Pi Great for 2A3
Next Topic: jbl single 2035H vs. dual 2226J shootout
Current Time: Sun Nov 29 01:09:56 CST 2026
