Home » Sponsored » Pi Speakers » Attention: If you own JBL 3677S click here
97dB [message #34938 is a reply to message #34937] Wed, 30 January 2002 07:50 Go to previous messageGo to previous message
250 watts is a 23dB increase over 1 watt, so if the 250 watt measurement maxes out at 120dB, I'd expect the maximum 1 watt SPL to be 97dB at 1 meter. I'm guessing at 250 watts, it is losing 1dB or so to thermal compression so it's 97dB to 98dB at 1 watt / 1 meter. At 500 watts, it probably loses 3dB to 4dB, but thermal losses aren't quite that high at 250 watts. Also note that Bill said the passband average was 115dB, so most of the bass range would be closer to 92dB. Used as a midwoofer in a two-way speaker, you can expect midrange output to be 3-6dB louder than bass below 100Hz.
Previous Topic: Possible use of Lambda woofer in Pi enclosure.
Next Topic: Beta site for midwest gathering
Current Time: Fri Nov 20 14:07:13 CST 2026
