Home » Sponsored » Pi Speakers » Theater 4 Pi Shopping List Questions (long)
Re: Theater 4 Pi Shopping List [message #34854 is a reply to message #34851] Wed, 23 January 2002 11:19 Go to previous messageGo to previous message
Your parts list is correct. You can also substitute the Peavey CH-3 horn for the H290. Check with Peavey's "dealer locator" to find the nearest source, if you're interested. For a connector panel, we use a connector panel that has bananna plugs with screw down terminals. Parts Express has an excellent gold plated bananna plug - screw mount connection panel for $4.00, Part number 260-309. You can use PVC tubing for your port if you wish. We use cardboard stock, 4" diameter with 0.080" wall thickness. You can find it listed as "BROWN MAILING TUBE .080 THICK". For acoustic insulation stuffing material, we use R-13 fiberglass insulation. Just remove the paper backing and glue or staple it in. Hookup wire should be a good quality oxygen-free stranded copper 14 or 16 guage speaker wire.
Previous Topic: producing techno + drum and bass
Next Topic: 4 Pis at low volumes
Current Time: Tue Nov 03 10:44:46 CST 2026
