Home » Sponsored » Pi Speakers » Wayne, bracing restricting port flow?
Yes, Adam [message #34846 is a reply to message #34844] Tue, 22 January 2002 13:47 Go to previous messageGo to previous message
Yes, absolutely. Preload can be applied by mechanical braces instead of filling the dead area with expansion foam. I like the expansion foam because it makes a solid damping mass, but you can also leave that area open as long as you use adequate bracing on the panels to keep them from vibrating.
Previous Topic: Four Pi Bass Reflex Driver mix of JBL HF motor & Delta 15 Pro
Next Topic: has anyone else used "minimal expansion" foam,
Current Time: Thu Oct 15 15:55:10 CDT 2026
