Home » Sponsored » Pi Speakers » Wayne, bracing restricting port flow?
Hey Wayne? [message #34844 is a reply to message #34843] Tue, 22 January 2002 13:26 Go to previous messageGo to previous message
Hey I know you said that the two chambers act as resonators in addition to the wood.
While my current plan is still the expanding foam, I have a question for you. Would it be sufficient to use conventional bracing methods to make the reflector panels (or folds or whatever you want to call them) completely rigid, and then leave the backs of the speakers completely open? See, as it stands, my speakers have no top, bottom or back. As I see it, if you didn't enclose the rear of the thing, the chambers wouldn't act as resonators because the standing waves would simply dissipate into the room.
So with plenty of bracing on the reflector panels and simply leaving the back of the speaker exposed, could you sucessfully solve both problems? At the cost of looks of course... Just curious.
Adam
Previous Topic: Four Pi Bass Reflex Driver mix of JBL HF motor & Delta 15 Pro
Next Topic: has anyone else used "minimal expansion" foam,
Current Time: Thu Oct 15 15:54:40 CDT 2026
