Home » Sponsored » Pi Speakers » Wayne, bracing restricting port flow?
Volume = capacitance; Restriction = resistance [message #34840 is a reply to message #34839] Tue, 22 January 2002 08:38 Go to previous messageGo to previous message
92 sq. inches. Hmm. Hard to say what the effects will be. Might be interesting to model it. The things to consider are displacement and area, basically how much pressure is exerted across the hole verses how much flows through it. The volume of each chamber acts as a capacitance, and any restrictions through the connecting hole will act as a resistance. Another thing to consider is standing waves, but only in the midbasss and midrange where the distances involved start becoming acoustically large, i.e. greater than 1/4 wavelength. Above that point you will start to see response rippling but not beneath it. At low frequencies, chamber features will be sensitive to pressure and at high frequencies, to standing waves.
Previous Topic: Four Pi Bass Reflex Driver mix of JBL HF motor & Delta 15 Pro
Next Topic: has anyone else used "minimal expansion" foam,
Current Time: Thu Oct 15 18:17:07 CDT 2026
