Home » Sponsored » Pi Speakers » ARE SCOOP BINS THE BEST FOR KICKIN' BASS
Bass horn size [message #34815 is a reply to message #34803] Fri, 18 January 2002 13:09 Go to previous message
It's all about size. A small scoop horn with short path length and limited mouth area is not good for deep bass. It's fine for midbass but can't hit the low notes.
I would not recommend augmentation of the bottom octave by EQ because distortion is terrible. If you increase power under horn cutoff to bring the deep bass up, then the distortion products are what are amplified by the horn. The horn doesn't amplify the fundamentals below cutoff, but it does amplify the distortion products.
So my conclusion is if you don't have the room to build a proper basshorn, don't build a truncated one. A properly tuned direct radiating sub is better than a basshorn run under cutoff and EQ'ed to compensate.
Previous Topic: crossover
Next Topic: Re: All American
Current Time: Mon Oct 26 08:45:04 CDT 2026
