Home » Sponsored » Pi Speakers » Bolt on horns/ drver for 4 Pi's- What Bolts?
1/4"-20 x 3/4" [message #34795 is a reply to message #34785] Thu, 17 January 2002 16:14 Go to previous message
The thread pattern used on the opposing pair of mounting holes is 1/4" diameter and has 20 threads per inch. The best length I've found is usually 3/4" because a 1/2" long bolt usually only "grabs" with one or two threads, if it reaches at all, and a 1" long bolt usually bottoms out. On some horns or adapters, you might need this long of a bolt, but then again, on many of them (like the H290), you have limited space to insert the bolt, so you must use a short bolt just to get it started.
Previous Topic: More Midwest Audio gathering stuff!
Next Topic: piezo
Current Time: Thu Nov 12 16:41:59 CST 2026
