Home » Sponsored » Pi Speakers » ARE SCOOP BINS THE BEST FOR KICKIN' BASS
"Scoops" aren't generally 20Hz horns, no [message #34764 is a reply to message #34761] Tue, 15 January 2002 21:55 Go to previous messageGo to previous message
Scoops are usually designed to work best above about 50Hz. They don't put out much bass in the 20Hz to 40Hz octave. That's fine for some applications where there isn't much below 50Hz to 60Hz or so.
If you need bass below 50Hz, you really shouldn't try to use a small horn. Either use a larger basshorn or if size is a constraint, use direct radiating subs instead. A woofer that I am particularly fond of is the JBL 2245. It sounds very nice when installed in a 10 cubic foot cabinet tuned to 30Hz.
Previous Topic: crossover
Next Topic: Re: All American
Current Time: Mon Oct 26 08:45:23 CDT 2026
