Home » Sponsored » Pi Speakers » initial thoughts on my ten pi's...
Re: Ten π assembly - Bracing and foam filler [message #34749 is a reply to message #34740] Mon, 14 January 2002 20:19 Go to previous messageGo to previous message
In the PiAlign program, there is a section at the far right of the screen that allows you to enter displacement volumes. There is also a little utility program called "Volume.exe" in the distribution archive that helps you calculate offset volumes. You can approximate the volume of drivers and other parts inside the cabinet using composites of primitives. For a full description of this process, please see the earlier post called "Displacement calculations (or measurements)".
Previous Topic: Impedance question for the smart guys
Next Topic: Rear ports for PA speakers?
Current Time: Sat Nov 07 05:28:09 CST 2026
