Home » Sponsored » Pi Speakers » initial thoughts on my ten pi's...
Re: initial thoughts on my ten pi's... [message #34743 is a reply to message #34732] Mon, 14 January 2002 17:39 Go to previous message
mikebake is currently offline  mikebake
BTW Adam, my Behringer x-over has mute buttons for each driver/frequency range; my system is set up correctly, and I am using JBL drivers; if I mute the mid/highs and listen to just the woofers, it sounds wierd; I could easily draw the conclusion that the woofers are doing bad things.....I agree with the other post that you should not draw any conclusions without the highs present, and before the project is correctly completed. On my system, with just the woofs playing, muddy seems to be the operative word, but it's just the perception without the full range reproduced.. Hang in there and complete the project as closely to the design parameters as you can.
Previous Topic: Impedance question for the smart guys
Next Topic: Rear ports for PA speakers?
Current Time: Sat Nov 07 05:28:13 CST 2026
