Home » Sponsored » Pi Speakers » Question for Wayne
Things and stuff [message #34741 is a reply to message #34700] Mon, 14 January 2002 15:36 Go to previous message
For acoustic damping material, I like to use R11 insulation which is 2" - 3" thick, uncompressed. It often has a paper vapor barrier that I peel off. There are lots of other materials and products that might work but R11 has always worked well for me.
You can put a grille over the port. A mesh or something like that would be just fine so long as it is non-restrictive.
For fasteners, I like T-Nuts for mounting heavy drivers or when serviceability is important. Wood screws are fine for about 20 tightening cycles but after that, the wood is stretched enough to tear through.
Previous Topic: show & tell
Next Topic: 1st-timer w/ 4 Pi Questions (kinda long)
Current Time: Mon Oct 05 13:59:22 CDT 2026
