Home » Sponsored » Pi Speakers » rc network with active crossover?
compensation network can still be used [message #34656 is a reply to message #34654] Mon, 07 January 2002 18:08 Go to previous messageGo to previous message
between the amp and driver, even with active. My HF drivers are at least 6, maybe 10 dB hotter than the LF system in use. When I go active, if I decide to implement top octave EQ, one possibility is use normal 2 way active xover, and use resistive padding and passive EQ on the HF driver as Wayne does. Or use more op amps. Passive EQ can be tweaked by ear easier. Sam
Previous Topic: horn cutting adventure, murphy helped too!
Next Topic: JBL flat frame loudspeakers
Current Time: Mon Oct 26 01:22:31 CDT 2026
