Home » Sponsored » Pi Speakers » Possible use of Lambda woofer in Pi enclosure.
Re: Possible use of Lambda woofer in Pi enclosure. [message #34637 is a reply to message #34634] Thu, 03 January 2002 09:42 Go to previous messageGo to previous message
Not sure what you mean... There are a lot of caps available in that size, it's pretty standard for crossovers. Not sure what you mean when you say cheap caps, like solen...
Solen, crescendo, dayton, etc.... Lots of choices.
If you don't want to spend the extra cash for these larger values, you can run a smaller value in parallel with an added electrolyte to get the same value. You'll get most of the sonic qualities of the poly cap without the extra price.
Adam
Previous Topic: Pi Four JBL Pro Plans
Next Topic: Attention: If you own JBL 3677S click here
Current Time: Fri Nov 20 14:25:47 CST 2026
