Home » Sponsored » Pi Speakers » Possible use of Lambda woofer in Pi enclosure.
Re: Possible use of Lambda woofer in Pi enclosure. [message #34634 is a reply to message #34633] Wed, 02 January 2002 19:45 Go to previous messageGo to previous message
Charlie G is currently offline  Charlie G
Looking at the Pi crossover schematic, the capacitors for the tweeter crossover are rather immense by audio standards. It pretty much eliminates film & foil caps, and all metallized caps except for very cheap ones, like Solen. The only other caps made in this size are Auricaps, costing $50 each (22uf). Any thoughts on the required quality of these caps, and/or what you'd recommend?
Thanks
Charlie
Previous Topic: Pi Four JBL Pro Plans
Next Topic: Attention: If you own JBL 3677S click here
Current Time: Fri Nov 20 14:25:47 CST 2026
