Home » Sponsored » Pi Speakers » Re: Enter PiAlign numbers in BoxPlot?
Re: Enter PiAlign numbers in BoxPlot? [message #34612] Tue, 01 January 2002 11:54
Click on "Box Parameters" and adjust the "Alpha" value to set cabinet volume until the bottom right corner shows "0.8 cubic feet." Adjust the "H" value until the Helmholtz resonant frequency shows 55Hz, which is also displayed in the bottom right corner. If you remove focus (go do something else) from the "Box Parameters" control, then you will have to close the contol box and re-open it by clicking "Box Parameters" again. To get very small changes, you might try typing into the "Alpha" and "H" fields rather than using the up and down arrows. At any rate, once you get the bottom right corner to display "Fs=55 Vb=0.80ft^3", the response curve shown is what Thiele/Small formulas predict for the PiAlign'ed cabinet.
Previous Topic: Enter PiAlign numbers in BoxPlot?
Next Topic: ASF-SB12 on the JBL tent sale page
Current Time: Sun Nov 29 17:27:53 CST 2026
