Home » Sponsored » Pi Speakers » Is this horn flare suitable for PSD2002?
Re: Is this horn flare suitable for PSD2002? [message #34563 is a reply to message #34562] Fri, 28 December 2001 10:20 Go to previous message
If I were planning to use a tweeter horn with a different pattern, I'd crossover at a different frequency to maintain DI matching. If the tweeter horn pattern is more narrow, crossover higher; If wider, crossover lower. The idea is to crossover in the frequency range where the direct radiating midwoofer pattern has narrowed to the same angle as the tweeter pattern in the horizontal. That way the sound is uniform throughout the room, within the vertical arc of the horn's pattern. Tweeter horns with asymmetrical patterns usually narrow more in the vertical than the horiozontal, which is a good thing in my opinion so it doesn't waste energy on the ceiling and the floor. You want the midwoofer pattern to match the tweeter's horizontal, because that makes off-axis response as smooth as off-axis response, which also creates a uniform reverberent field.
Previous Topic: All the T-S parameters for every JBL, OH BOY!
Next Topic: Wayne, double loading
Current Time: Tue Nov 03 14:38:47 CST 2026
