Home » Sponsored » Pi Speakers » Is this horn flare suitable for PSD2002?
Re: Is this horn flare suitable for PSD2002? [message #34562 is a reply to message #34560] Fri, 28 December 2001 03:08 Go to previous messageGo to previous message
Super_BQ is currently offline  Super_BQ
I've looked at the Sammi line of horn flares then found that they are a little different than the CH-3, 2370, or H-290 flares.
The Sammi SH350 is a bolt on exponential horn similar to what is required for the Theater 4 Pi's however, it's dispersion is quite different. It offers a 120°H x 90°V with a cut-off freq. of 600 Hz. I believe the 2370 and similar flares use a 90° X 40° dispersion.
Wayne, what effect would using the SH350 wide dispersion have over the typical 2370 size horn flare for the Theater 4 Pi?
Previous Topic: All the T-S parameters for every JBL, OH BOY!
Next Topic: Wayne, double loading
Current Time: Tue Nov 03 14:39:19 CST 2026
