Home » Sponsored » Pi Speakers » Is this horn flare suitable for PSD2002?
Is this horn flare suitable for PSD2002? [message #34560] Fri, 28 December 2001 00:56 Go to previous message
hjeon is currently offline  hjeon
Hi Wayne...
I bought a horn flare made by Sammi here in South Korea.
It resembles CH-3 but a little bigger.
Mouth size is 15 x 5 inches and depth is 7 inches.
so the mouth area is 75 square inches
So the horn cut off frequency is a little lower
than either CH-3 or H290 since the mouth area is bigger.
It is a bi-radial with diffraction slot at the end.
Do you think this is suitable for the PSD2002 on theater
4 pi?.
Or should I buy another horn flare?.
What effect can we expect by using bigger(lower cut off)than normal
horn flares?
Sammi make sh-350 which is similar to h290 by look and spec.
They also make sh-360 which is similar to ch-3.
If I have to buy another horn which one do you think is better?
Thanks in advance
Hunmoo
Previous Topic: All the T-S parameters for every JBL, OH BOY!
Next Topic: Wayne, double loading
Current Time: Tue Nov 03 14:39:14 CST 2026
