Home » Sponsored » Pi Speakers » Crossover help: more confused than ever!
Kama Sutra Series/Parallel [message #34520 is a reply to message #34518] Sat, 22 December 2001 10:48 Go to previous messageGo to previous message
When two equal value resistors are connected in parallel, the resistance is halved and the power handling is doubled. This is largely because there is now two current paths, and power dissipation is split between them so capacity is doubled. When equal values are connected in series, current is now reduced - cut in half. This also means that the voltage across each resistor is made 1/2. So combining these effects, you now get 1/4th power across each series component that you would have had if the component were connected by itself.
Previous Topic: Theatre 4pi
Next Topic: Wooden Horn Update
Current Time: Tue Nov 03 06:38:39 CST 2026
