Home » Sponsored » Pi Speakers » Extended High End on Compression Drivers
Re: Extended High End on Compression Drivers [message #34443 is a reply to message #34442] Sun, 16 December 2001 11:09 Go to previous message
The built-in CD equalization in the Behringer crossover (and other active crossovers) is intended to do the same thing as the top-octave compensation in my passive crossovers. So just switch it in when using a horn that needs it.
The horn isn't actually what causes rolloff at high frequencies, it is the driver. Some horns provide acoustic EQ from collapsing directivity. Naturally, if directivity is constant, no acoustic EQ is provided so electrical EQ is desired. Some horns provide constant directivity in the horizontal plane but collapsing directivity in the vertical plane, so they'll need less EQ.
Another thing to consider is the shape of the response curve. Most 1" compression drivers have pretty flat response up to about 3kHz - 5kHz. Above that, response falls off at a 6dB/octave slope for an octave or a little more, to the upper cutoff point, where response drops rapidly. The conjugate curve for power response isn't a diagonal line, rather, it starts off with flat response up to 3kHz - 5kHz and then starts to rise.
Previous Topic: Re: Cool rendered image!
Next Topic: Wayne, creating large corner horn for non-corner use...
Current Time: Sat Oct 17 15:22:20 CDT 2026
