Home » Sponsored » Pi Speakers » Kilomax vs Kappa Pro 15LF - what's the diff in "sound"?
Re: Kilomax vs Kappa Pro 15LF - what's the diff in "sound"? [message #34437 is a reply to message #34423] Sun, 16 December 2001 08:48 Go to previous message
freddyi is currently offline  freddyi
Hi George!
you must be getting some good sound - I don't think a graph tells all the sonic story of a woofer's performance - Eminence's graph shows some rolloff but your Kilomax must be doing ok in the xover region or you wouldn't be so darn happy. I wish Eminence would detail conditions and give off axis data.
btw-I have a Behringer xover but had ground loop problems - will have to sort those out.
I need to locate some of the 1" Russian plywood - hope 84 lumber can order - you got it for only $30/sheet!! - I'd be happy @$50-60 for 5x5 - I'd be in 'box heaven' with 4-6 sheets!
Best wishes!
Freddy
Previous Topic: JBL 2235
Next Topic: Folded horn with multiple woofers
Current Time: Sun Nov 22 21:41:47 CST 2026
