Home » Sponsored » Pi Speakers » Kilomax vs Kappa Pro 15LF - what's the diff in "sound"?
Re: Opinions from Kappa owners requested - how 'bout 2-15"/side Pi? [message #34436 is a reply to message #34429] Sun, 16 December 2001 08:37 Go to previous messageGo to previous message
freddyi is currently offline  freddyi
Hi Adam
thanks for the detailed reply, What are you using on top, a 2370? - I already own 2-cast frame Eminence from MCM a few years ago - just sitting in their boxes - I think they are essentially 2.5" voice-coil Delta Pro - (also Dayton 295-070 - they don't go high - their curvlinear cones are doped and dust cap kinda large...dunno why they were executed that way)
I'll sure have to check into the Kappa 15LFA - one consideration with solid state amps would be to use 2-15LFA/side (or whatever) stacked tight vertically so a horn can be used on top (D'Apollito may be Ok?) - what do you think of 2-15/side with horn on top? - cost wouldn't be much more - should have some serious "punch". Also - pretty much sure woofers with dissimilar fs can work well in one box --tends to flatten the Z curve (ala' VMPS)
btw - what size box and tuning do you suggest for Kappa 15LFA?
Best wishes!
Freddy
Previous Topic: JBL 2235
Next Topic: Folded horn with multiple woofers
Current Time: Sun Nov 22 21:41:50 CST 2026
