Home » Sponsored » Pi Speakers » Mystery Drivers & Plans for the Pi 6 Theater
Measurement equipment and software [message #34301 is a reply to message #34299] Sat, 01 December 2001 19:59 Go to previous message
I suggest using the Woofer Tester from Parts Express or Speaker Workshop from Audia. You can also measure them yourself using the following technique and formulas:
You'll need a signal generator and meter or scope. Put a test resistor in series, something between 10 and 1000 ohms.
Find Re. It is the DC resistance of the voice coil.
Find Fs. It is the frequency where impedance is highest.
To find mechanical and electrical Q values, the following formulas are used:
Qms = Fs * (Zmax/Re)0.5 / (Fh - Fl)
Qes = Qms / (Zmax/(Re - 1))
Qts = Qms * Qes / (Qms + Qes)
where
Fs is the resonant frequency of the speaker in free air (Hz)
Zmax is the impedance of the speaker at resonance in free air (ohms)
Re is the DC resistance of the voice coil (ohms)
Fh is the frequency above Fs where speaker impedance is (Zmax*Re)0.5
Fl is the frequency below Fs where speaker impedance is (Zmax*Re)0.5
Note: Fl and Fh can also be found at the points where voltage across the test resistor is equal to Vq in the follwing formula:
Vq = (Vmax*Vmin)0.5
where
Vmin is the voltage across the resistor at the speaker's resonant frequency
Vmax is the voltage across the resistor at a frequency far from resonance
To find Vas using the sealed box method, the following formula is used:
Vas = Vb((Fb / Fs)2 - 1)
where
Vb is volume of the sealed cabinet (ft3, m3 or liters)
Fb is the resonant frequency of the speaker in the box (Hz)
Fs is the free-air resonance of the speaker (Hz)
Previous Topic: Hats-Off to replay (George)...
Next Topic: Port detail for pro 7 pi's
Current Time: Sat Nov 28 23:03:56 CST 2026
