Home » Sponsored » Pi Speakers » maximum power handling of my 4 pi's
Re: maximum power handling of my 4 pi's [message #34256 is a reply to message #34252] Mon, 26 November 2001 15:47 Go to previous messageGo to previous message
I prefer to use (4) 10-12 watt components in series/parallel to form a resistance that can handle more current without getting hot. Even at low power levels, this is an advantage because the parts run very cool.
As for capacitors, two in parallel adds their capacitance (like series resistors) but the voltage across them remains the same. If you have two caps in parallel, one rated for 250v and the other rated for 400v, the maximum safe voltage is 250v. If you apply 300v across the caps, the one with lower voltage rating will eventually fail.
Previous Topic: xover question
Next Topic: Re: maximum power handling of my 4 pi's
Current Time: Wed Oct 21 21:36:49 CDT 2026
