Home » Sponsored » Pi Speakers » 3 Way Seven Pi crossover, with JBL CS3115 Parts
3 Way Seven Pi crossover, with JBL CS3115 Parts [message #34155] Wed, 14 November 2001 19:30 Go to previous message
Hi Wayne,
Thanks for all you're help. The crossover diagrams you make are easy to follow. Designing the crossover and "really" understanding it, is something I have difficulty with.
When you get a free moment (I know your very busy) If you could help me with a crossover, I would greatly appreciate it.
Here are the drivers I wish to build into a seven Pi.
All specs are from JBL.
Low frequency;
2226G 4 Ohms sensitivity 89db spl 1/1
Mid frequency;
M209-8 8 Ohms sensitivity 105db spl 1/1 (with horn)
Fs 91hz Re 4.9 Le .265mH Qts 0.385 Qms 2.04 Qes 0.475
High frequency;
2425HS 8 Ohms sensitivity 111db spl 1/1 (with horn)
JBL has recommended in their tuning specs to cross these parts at 420hz, 1.6khz
Attenuating with
+2db woofer
-5db mid
-10db Tweeter
I dont know that this would be the same in a Seven Pi corner horn, but It might be helpful information.
I think this will make a great Seven Pi corner horn.
Thanks,
Bill
Previous Topic: Question for Wayne: Cabinet Proportions and Sizes
Next Topic: 2226h drivers for $251.99
Current Time: Fri Nov 20 08:25:40 CST 2026
