Home » Sponsored » Pi Speakers » Pictures of DIY Theatre 4 Pi
Re: how do you like the cambridge? [message #34145 is a reply to message #34142] Fri, 09 November 2001 07:40 Go to previous messageGo to previous message
The Cambridge gives the lie to multi-thousand$$$ decks. With every upgrade of pre-amp, amps and cables, something once hidden is revealed. I'm now convinced that, jitter and distortions under control, ones is ones and bits is bits.
The Foreplay is half torn apart and 2A3 Paramours are on the way.
That's why I'm listening to the Outlaw A/V receiver on the shelf. And it sounds damned fine! For Transistors!
Previous Topic: voigt pipes vs corner horns
Next Topic: Re: md2001 only speced to 12 kHz?
Current Time: Mon Oct 19 20:31:49 CDT 2026
