Home » Sponsored » Pi Speakers » Bracing: expansion foam
Re: Bracing: expansion foam [message #34087 is a reply to message #34086] Thu, 25 October 2001 03:57 Go to previous message
I agree with your carpenter. My experience has been that a properly glued joint is stronger than the wood itself, in most cases. So it is not important to use screws, even on large cabinets. My cabinetmakers have stated this, and I've seen evidence that tends to confirm it. Cabinets that are damaged by strong impact often have broken panels, but glued joints remain intact.
Having said that, my cabinetmakers still use screws in some places within complex cabinets. They are used as clamps to provide hold-down strength while the glue is drying. They actually could be removed after the glue dries, but there really is no need. So they're left in place.
Previous Topic: Crossover placement question
Next Topic: DIY Theatre 4PI: First impressions (unforgiveably long)
Current Time: Tue Oct 20 22:46:25 CDT 2026
