Home » Sponsored » Pi Speakers » Compensation components w/ 6db slopes?
Re: Compensation components w/ 6db slopes? [message #34027 is a reply to message #34026] Mon, 08 October 2001 20:32 Go to previous messageGo to previous message
I would not recommend a variable L-Pad, but would recommend a series/parallel attenuator using fixed value resistors. Put an HF augmentation capacitor across the series resistor.
The network I use in my speakers will work for you, using values R1=16 ohms, R2=30 ohms and C1=0.47uF. It is a little different configuration than usual, with the shunt resistor in front of the series resistor, because it was designed to provide a specific amount of damping for my crossover. But it will work for you very nicely. Load impedance is about 12 ohms, so keep that in mind when choosing your crossover cap.
Previous Topic: JBL E155-4
Next Topic: 2426H drivers FS- $300 for the pair
Current Time: Wed Oct 21 22:37:24 CDT 2026
