Home » Sponsored » Pi Speakers » JBL E155-4
Re: JBL E155-4 [message #34014 is a reply to message #34013] Sat, 06 October 2001 09:21 Go to previous messageGo to previous message
Frode is currently offline  Frode
My question is, how can you tell if response curve "sounds good", and how do you tell if the distortion is low? Some drivers goes pretty low with a "normal" roll-off, while others need an alignment which gives some kind of extended shelf in the response to give low bass. Is everything "OK" as long as the curve is smooth, or should I look for something else?
Previous Topic: Our Crusade message for the Taliban
Next Topic: Compensation components w/ 6db slopes?
Current Time: Wed Oct 21 21:36:40 CDT 2026
