Home » Sponsored » Pi Speakers » Port length on multiple ports
PiAlign'ed at 2 cu ft tuned to 20Hz [message #33958 is a reply to message #33957] Fri, 28 September 2001 06:27 Go to previous messageGo to previous message
You have a motor with these specs:
Vas=5.33 cu ft
Fts=21Hz
Qts=0.39
So PiAlign equivalents are:
Vad=5.33
Frd=21Hz
Qd=2.56
PiAlign recommends a 2 cubic foot cabinet tuned to 20Hz using either a cylindrical 5" long, 1 5/8" diameter port or a rectangular 1" x 2" x 5" long port.
You can grab a copy of BoxPlot on the Pi Speakers website to show the response of this cabinet using Thiele/Small analysis. The box you've proposed is about 5 cubic feet, and I suspect that will work just fine. The driver will probably work very well in cabinets from 1.5 cubic feet to 6 cubic feet or so, tuned to 20Hz. You can use BoxPlot to find an alignment that will give acceptable response in this size cabinet.
Previous Topic: theil-small params for Fostex FE-103 (RS 40-1197)
Next Topic: Eminence 12LT Pi BR Qestion
Current Time: Sat Oct 24 00:22:36 CDT 2026
