Home » Sponsored » Pi Speakers » Crossover document - Rough draft
Re: Crossover document - Rough draft [message #33880 is a reply to message #33868] Thu, 20 September 2001 09:19 Go to previous messageGo to previous message
Crazy Dave is currently offline  Crazy Dave
This paper is exactly what I've been thinking about. If I understand correctly, you are using a simple 6db first order crossover and also compensating for the horn’s non-linearity. As you pointed out, there are driver interaction problems with this much overlap, but I still think there is a lot of potential with this type of system. I think is should be very easy to drive and sound good.
I have printed this paper and after I go over it in depth, I will get back to you.
Thanks for the excellent analysis!
Previous Topic: 10 Pi and Celestion 18"
Next Topic: *** Woofer Enclosure ***
Current Time: Sat Nov 28 17:19:44 CST 2026
