Home » Sponsored » Pi Speakers » Eminence 12LT Pi BR Qestion
Re: Good luck and keep us posted! [message #33808 is a reply to message #33807] Wed, 05 September 2001 05:23 Go to previous messageGo to previous message
Observator is currently offline  Observator
Hi Jeff,
> I built Thorsten's Afterburner but am now going to try the Beta12LT
> in a PI cabinet.
From my side, I was inspired by reviews about hammer dynamic
super12. I haven't possibility to hear it, so i decided first
to build afterburners for having an idea how 12" FR performs.
what's your opinion ? Can you compare it with something I
know ;-), let say FE103 or 40-1354 or FE208s....
what's also your amplifier ?
> Do you have the Rat Shack tweet? I found them too bright--could be
> too sensitive or the 1st order crossover isn't attenuating quickly
> enough so there's too much overlap at 8-10kHz.
> I'm going try a piezo tweet with a second order crossover.
Thanks for your advice, i haven't possibility to buy RS tweeter
here so I had the same idea as you - Motorola piezo. Which one
is your favorite ?
And, what about adding a low-pass and zobel for beta12tl same as
used in super12 ? This could be a solution to clarify the 10k region.
> Good luck and please let us know how it goes,
> Cheers,
> Jeff
thanks, I will do
O'Tor
Previous Topic: Port length on multiple ports
Next Topic: XO-slope for sub
Current Time: Thu Nov 19 21:14:58 CST 2026
