Home » Sponsored » Pi Speakers » Thermionic four Pi's sound "horny"
"Nasal" sound [message #33780 is a reply to message #33779] Sat, 01 September 2001 19:53 Go to previous messageGo to previous message
The sound you're describing is a sort of "nasal" sound, yes? Or is it more of being "surrounded by treble?" If it's the former, then I'll bet we have problems with the crossover. If the latter, then it may be your room. If it's the room, then every speaker should sound bad there. If that's the case, then check out the post called "Solution for raised wood floors and crawlspaces." It might give you some good ideas.
Previous Topic: One more Q
Next Topic: Parts shopping Q
Current Time: Wed Oct 21 13:09:23 CDT 2026
