Home » Sponsored » Pi Speakers » Capacitors
Re: Capacitors [message #33655 is a reply to message #33654] Thu, 09 August 2001 21:27 Go to previous messageGo to previous message
Wayne: I had written you about active crossovers recently... what kind of caps are best for this purpose... more likely to be close to marked value, etc? Are 5% resistors close enough?
As you know, I was looking at xover freq in 800 hz range, for a two way system. So, my questions are:
Is 12 db/oct rolloffs enough, or should I go for 18 or 24 db/oct?
If I cascade two 12 db/oct filters, the Fx point will be -6 db instead of -3 db. Should I overlap the hi pass and low pass a little more?
I had sent you active filter topologies I had gotten from two different sources... one from a Radio Shack op amp book, where all C = C and all R = R. Values were computed from Fx = 1/(2piRC). The second was the same topology, but values were not equal, and it was described as "Butterworth". I am more the KISS type, and was leaning toward the former equal value circuit.
As op amps, resistors and caps are cheap these days, I am leaning toward 24db/oct. (I remember as a kid paying $1.50 for a diode for a "crystal radio". Oh, I could pick up two stations with mine!)
Suggestions?
Previous Topic: altec 604-8g in pi enclosure
Next Topic: 2A3 (Paramour) / Thermo et al
Current Time: Tue Oct 20 16:13:19 CDT 2026
