Home » Sponsored » Pi Speakers » Can someone decribe the sonic differences between the 2426H and PSD2002 drivers?
Match front speakers, center channel most important! [message #33646 is a reply to message #33645] Tue, 07 August 2001 05:22 Go to previous messageGo to previous message
AudioLapDance is currently offline  AudioLapDance
Hey James,
As Wayne knows I'm an advocate of what "the man" recommends (see www.dolby.com) Keep those three front channels matched! For proper panning across the front these channels should be as close as possible--same drivers, same cabinet, same tilt, same positioning vis a vis walls, floor ...
To me, the center channel is even more important than left or right so you could even go with PSDs on the sides and the 2426 in the center. But if the system is for stereo too then hmmm... the choices aren't as clear.
Remember to put your receiver in 'wide' mode so that the center channel is getting the bass it's supposed to; this definitely seems to 'center' the sounds more. With 15" in the center ... I hope you don't have any close neighbors!
I'm sooo jealous; your home theater is going to rock!! I take it you have a projector and screen?
You should charge admission!
Good luck,
Jeff
Previous Topic: how many watts would 2 eminence12" woofers make?
Next Topic: Is JBL overpriced or are the high costs justified?
Current Time: Tue Oct 20 13:49:33 CDT 2026
