Home » Sponsored » Pi Speakers » Studio One Pi's or Two Pi's?
Re: Studio One Pi's or Two Pi's? [message #33615 is a reply to message #33613] Mon, 30 July 2001 04:40 Go to previous message
Both are very good sounding speakers, and particularly in small rooms. The two Pi does go a bit deeper, enough that you notice.
All the larger speakers use T-Nuts but the smaller ones like the one Pi and two Pi use wood screws. The holes are drilled first, so the installation is clean. It wouldn't be much extra trouble to substitute T-Nuts for wood screws, but you won't need them unless you think you'll be opening them up a lot.
We don't make grilles. If grilles are desired, I suggest using velcro strips and generic grille foam. We did make grilles at one time. The first cabinetmaker I worked with - who still lives here in Tulsa, by the way - made frames and stretched wicker over them. The frame was then attached with velcro, similarly to the foam I've suggested. The framed wicker grille wasn't very heavy, so velcro mounting worked very well. I can ask him if he would be interested in building you a pair.
Previous Topic: Flares for PSD2002 in Theater Four Pi.
Next Topic: Yet more 4 Pi questions
Current Time: Tue Oct 20 14:53:07 CDT 2026
