Home » Sponsored » Pi Speakers » Piezo Curves
Hmm-ing, now aha-ing! [message #33544 is a reply to message #33542] Thu, 12 July 2001 00:10 Go to previous messageGo to previous message
AudioLapDance is currently offline  AudioLapDance
If Andy G's gracious graphs are calibrated so the 0dB line is the sensitivity in the spec sheet, then the KSN1165 is at LEAST 3 dB louder than the KSN1025/1141. The 1025 is usually rated between 95 and 98 dB so that implies that the 1165 is at least 98 or 99 dB.
The KSN1188 should be using the same 0 dB calibration as the 1165 because both are rated as 93 dB/2.83V. The 1188 looks at least as sensitive as the 1165 so it should be around 99 dB too!
Attacking from another direction, Paul C seems to know his terminals from his tractrix horns. Indeed, Andy G's KSN1005 graph explains why Paul was "less than impressed by the 5khz peak in the little KSN1005... a harsh one note cymbal sound." Paul's trumpeting of the 1188 strikes a cord with me.
So I'm gonna go with the KSN1188 and hope it comes close to the 100-ish dB of the Delta 15. QED. Whew, that felt good!
So now onto the 1188. The graph shows that it doesn't roll-up a la 3rd order like the other piezos. I'm thinking that this must be a measurement glitch since Paul said he successfully ran it with no crossover. The -3dB point looks like ~ 600 Hz (!wow!) so I'm thinking I'll put a 400 to 500 Hz second order on the Delta (does any one have a more precise suggestion?) I bet the Delta will like this low down, double crossing! ;-)
Do I need to worry about throat distortion with this horn trying to go so low?
Thanks for your help guys,
Best regards,
Jeff
Previous Topic: Flanking Subs vs Helper Woofers, revisited
Next Topic: Notes on Ironing Veneer, Using Watco and ... a distress signal?
Current Time: Wed Nov 04 06:50:17 CST 2026
