Home » Sponsored » Pi Speakers » SPL question
Re: SPL question [message #33476 is a reply to message #33475] Tue, 26 June 2001 12:00 Go to previous messageGo to previous message
Thanks for the link, James. Can't agree with them about horn loading though. You can always screw up anything, and horns are no exception. But a well built horn provides high output, smooth response, low distortion and controlled directivity. To be honest, the only valid argument I can see against horns is their size. But in a prosound environment, this vanishes. You're dealing with large spaces, so you can make large cabinets. In this case, the size of horns isn't a problem. In fact, the end result is smaller, because a horn produces more sound per cubic foot than a direct radiator does.
Previous Topic: To Wayne.
Next Topic: big improvement
Current Time: Mon Nov 23 00:47:41 CST 2026
