Home » Sponsored » Pi Speakers » Variable x-o for motorola KSN1142
KSN 1038 as a "Super Tweeter" [message #33439 is a reply to message #33438] Thu, 21 June 2001 02:35 Go to previous messageGo to previous message
You might be interested in the post called "Pi implementations of quartz piezoelectric tweeters", and in the links to other threads that are contained in this post. As for a specific sugegstion, you might try this:
=== 10kHz Filter ===
Series Capacitance = 1.0uF
Parallel Resistance = 16 ohms
freq resp
20kHz -1 dB
10kHz -3 dB
5kHz -7 dB
2.5kHz -13dB
That will give you some subtle "sparkle" and is probably what you're looking for.
Alternately, I'll describe the exact filter you've asked about, which is a first order 20kHz network. If this is what you want, you'll need a capacitor that's exactly half as big as the one listed above. So you'll want a 16 ohm resistor across the tweeter, and a 0.47uF capacitor in series with the tweeter/resistor connection.
This will give the following response curve:
=== 20kHz Filter ===
Series Capacitance = 0.47uF
freq resp
20kHz -3 dB
10kHz -7 dB
5kHz -13dB
2.5kHz -19dB
A KSN 1038 using this second filter might add some "air," but it will be crossing over pretty high.
Previous Topic: Bracing, cabinet volume, and crossover questions
Next Topic: i'm a canuck eh!!!
Current Time: Sun Oct 25 07:31:00 CDT 2026
