Home » Sponsored » Pi Speakers » JBL 2241 Prof series
Re: Ok...what would you drive them with? [message #33305 is a reply to message #33304] Fri, 04 May 2001 18:23 Go to previous messageGo to previous message
That'll be enough for a small room, under about 500 square feet. At maximum output, it's about 107dB at 39" (1 meter) distance. Double the distance, subtract 6dB, i.e. 101dB @ 6.5 feet, 95dB @ 13 feet. You might want to use more power in larger rooms, maybe a plate amp for the bass bin and your 300B's for the tops.
Previous Topic: screw-on adapter found
Next Topic: A little TAD, Beyma comparison
Current Time: Thu Nov 19 20:30:21 CST 2026
