Home » Sponsored » Pi Speakers » Are all screw-on piezo horn drivers similar ?
Re: More piezo stuff - high order networks, etc. [message #33286 is a reply to message #33284] Wed, 02 May 2001 23:42 Go to previous messageGo to previous message
The tweeters I use don't have any sort of connector lever. They all have a small 1" paper cone that is directly glued to the quartz element. This is the case for the KSN1038, 1041 and 1056. Motorola piezoelectric tweeters in this family use the same motor/diaphram - having this 1" paper cone and three screws that mount it to the horn flare.
All of my larger speakers use compression drivers, and I only use the piezo in speakers that won't be used much above 30v. I really like the little Motorola tweeters, but I find them best suited for smaller systems. But then again, I've run 'em for years on ultra high powered Crown amps, and never smoked one. They should burn out at about 40v, but I've just never smoked one. The woofers in these systems will fail long before the tweeters, and that is probably one reason why I haven't damaged a quartz tweeter. They're just in smaller systems.
Previous Topic: Bellingham?
Next Topic: Probable dumb question - Where's the midrange driver?
Current Time: Wed Nov 04 00:38:45 CST 2026
