Home » Sponsored » Pi Speakers » Variable x-o for motorola KSN1142
Modified Variable x-o for motorola KSN1142 [message #33211 is a reply to message #33210] Wed, 18 April 2001 01:13 Go to previous messageGo to previous message
Andy G is currently offline  Andy G
After feedback from John Risch on the Mad Board, I have made the following changes. He actually suggested using switched capacitor values, but I guess what I was trying to do was to make a variable piezo x-o with the components I have in stock. I have 4 of those 8 ohm L-pads in stock, an was trying to find a way of using them, rather than buying extra rotary or other switches.
If I remove the 1.5µF cap (doesn't seem necessary) Put 22 ohms across the piezo and add a 15 ohm in series with the parallel leg of the 8 ohm L-pad and push the x-o frequency up to 4500 calculated on 16 ohms (2.2µF), The R1 resistor would be set for the half way position on the L-pad, giving partial cut and gain. (I know that it would not give the same dB cut as on the face-plate of the L-pad, but I wasn't planning to use it anyway.)
Do you reckon it would work ok?
My calcs seem to indicate that the resistance seen by the x-o capacitor would vary between 15.2 and 16.9 ohms. This is probably quite a bit more stable than a normal driver.
Previous Topic: Bracing, cabinet volume, and crossover questions
Next Topic: i'm a canuck eh!!!
Current Time: Sun Oct 25 07:30:41 CDT 2026
