Home » Sponsored » Pi Speakers » Variable x-o for motorola KSN1142
Re: Variable x-o for motorola KSN1142 [message #33210 is a reply to message #33207] Wed, 18 April 2001 00:12 Go to previous messageGo to previous message
Your crossover is cool, but you will find that the 30 ohm R1 will slightly reduce output in the top octave. From 10kHz to 20kHz, the tweeter's impedance is less than double this value, and nearly equal at 20kHz. So you might use a smaller value series resistor in position R1. Another thing you might do is to add about 20 ohms directly across the tweeter. That will make the load presented to the crossover be nearly equal to the shunt resistance. That will allow you to design a crossover just like you do for any other driver, knowing the shunt resistance value to be the load impedance for crossover component value calculations.
Previous Topic: Bracing, cabinet volume, and crossover questions
Next Topic: i'm a canuck eh!!!
Current Time: Thu Sep 10 20:57:50 CDT 2026
