Home » Sponsored » Pi Speakers » Baffle spacing, crossovers and phase angles
Re: Baffle spacing, crossovers and phase angles [message #33148 is a reply to message #33143] Fri, 06 April 2001 06:52 Go to previous message
Scholl is currently offline  Scholl
sounds like a good techno point for 15" two way designs. With a wide selection of mid\high horns available voice coil spacing can be factored into the design by choosing a horn considering its depth. With a little help from plywood, woofer\horn spacing can be fine tuned. The main caviat is, its hard to get a 95db+ 15 to go below 40hz and a midrange horn to go above 15khz. TAD products look to do the best in the simplest design.
Several years ago Speakerbuilder mag had an artical that ploted phase with various crossover slopes. The artical was good for info in considering driver spacing.
Previous Topic: Check out the coolest site ever
Next Topic: Chesky/Martin Logans
Current Time: Sat Nov 07 04:35:18 CST 2026
