Home » Sponsored » Pi Speakers » scanspeak 10"
scanspeak 10" [message #33131] Mon, 02 April 2001 00:08 Go to previous message
dtkky is currently offline  dtkky
Hello Wayne,
I have been surfing your website and would really like to try building a pair of corner horns for some scanspeak 10" that I have. The T/S parameters are as follows:
Sd 298cm2
Vas 270 litres
Fs 20 Hz
Qts 0.22
Xmax 5.5mm
Re 5.5 ohms
Pmax 130W
Le 0.12mH
Sns 91 dB
Do you think it's feasible to cover 30Hz to 500 Hz?
Your Pi-align software suggested a 2.1 cu.ft. box tuned to 34.5 Hz. (correct me if I'm wrong). This is smaller than what Boxplot suggests as optimal. Is this always so?
Also, can I stack 2 corner horns one on top of the other with a midrange horn in between? (D'appolito style)
I would really appreciate your words of wisdom before I start cutting up my wood.
David Tan
Previous Topic: theater 7 x-over
Next Topic: Check out the coolest site ever
Current Time: Mon Oct 19 20:32:09 CDT 2026
