Home » Sponsored » Pi Speakers » Are all screw-on piezo horn drivers similar ?
Re: Are all screw-on piezo -thanx Motorola sheet - using piezo w. tube [message #33111 is a reply to message #33110] Fri, 30 March 2001 16:33 Go to previous messageGo to previous message
freddyi is currently offline  freddyi
Wayne -
A Piezo can be quite good - I wouldn't worry about the rising Z using with a tube amp IF its a speaker without an xover on the woofer but has a 'Zoebel" conjugate network on that woofer - then the overall Z seen will be ~ that of the woofer plus conjugate in he xover region.
I might want a small resistor in series with the piezo in case the amp doesn't like capacitive loads at HF - what value of series do you suggest? (I think~2 ohm ok without much loss)
btw - you can try using a little speaker distribution xformer to get more spl out of the piezo - I think you then need a conjugate RL network to compensate for the capacitive nature - you might get ~105dB sensitivity that way - kinda a hassle when Foster horns are available cheap
Best Wishes!!!!!
Freddy
Previous Topic: Bellingham?
Next Topic: Probable dumb question - Where's the midrange driver?
Current Time: Tue Nov 03 22:27:56 CST 2026
